Hi all!
We have now moved into the new house, made a decent dent in the box unpacking and the de-catifying is going well (14 years of 7 indoor cats is quite a challenge) and husband is bearing up with lots of antihistamines.
Obviously, I have been unable to restrain myself from having a poke around to see what things are made of so that we can get an action plan together.
The electrics are scary so things may need to happen sooner rather than later. However, we want to chase wiring into the walls rather than have the cables everywhere as they are now. Hence the poking about...
I've discovered that the vendors idea of repair work was to fill any gaps/holes with spray-on expanding foam, slap a bit of plaster on and hold everything together with multiple coats of gloss paint. Marvellous!
I had a look at the wall above my daughter's bedroom door - stuck a knife under the edge and the paint/plaster literally fell off leaving a panel of what looks like wattle & daub. Will take some pics, but it looked like brown mud with bits of straw and other stuff mixed in. Panel is in really good condition. Having tapped the other internal walls in the same area and I'm pretty sure they are the same.
Then I had a look at the main wall along the stairs which I know is lath & plaster as I can see the other side of it.
The wall looks like lumpy, shiny, yellow gloopy. It feels bubbly and crunchy and cracks if you press on it. It got some damage in the move with furniture being taken up and down (v narrow staircase).
I used a scalpel and there were a number of layers. 4 or 5 layers of paint, then a layer of modern plaster of varying thickness, then a layer of very old lime plaster on top of the laths. The whole of the plaster has come away from the laths. Where there were holes, it had been filled in with either 1-2 inch thick modern plaster, or the spray-on foam. I carefully cleaned down to the surface of the old plaster, but there are lots of areas where it's so cracked it's just a mess of crumbly bits of lime plaster.
The laths are in really good condition, but it looks like the whole plaster layer has become totally separated.
The other side of the wall is the one that the CO and the surveyor were interested in as it shows smoke blackening and is historic fabric. As it's the inside wall of a very large storage area it's not been touched and is in very good nick.
What should I do in terms of re plastering the wattle & daub and more importantly, dealing with this wretched mess of a wall?
