A
Anonymous
Guest
Darn, darn, darn! I covered about 50 square feet of wall with finish plaster yesterday which began to crack almost right away and according to my friend doing the follow up water spraying, cracked off part of the wall after I left! Aaagghhh!
What the heck am I doing wrong?
I thought the cracks before were a result of having no one there to spray the walls after application for a slow cure. Apparently not.
I have a fine lime finish plaster-dry mix w/ sand already in.
I prepped the walls ahead by having them sprayed.
Covered my plaster washers with mesh tape embedded in putty.
I primed walls over all with a mix of lime putty and water.
Did my first ever Large Batch of a 50# bag with 1 gal, 12 oz water as recommended. Used a hand mixer that attaches to a drill. (Not fun. I kind of liked kicking a small batch bag around better.) Water in first, then plaster mix. 20 min of mixing (plus more water) to get a workable product.
A. First problem-mix balled up like lots of walnuts--very dry. Added some more water. And more... *Finally* got a product that would stick to trowel and not fall off AND stick to wall without falling off if I flung it.
Question one: what is the maximum amount of water that you would DARE add to a 50 pound bag of lime mix to get workability? Maybe that 140 oz water was somehow supposed to incorporate if I mixed it Forever and would eventually get all nice and spreadable. Maybe I need a more powerful kind of mixer. Maybe I should stick to small batches.
B. What to use to put finish coat on wall--I used a mixing trowel held an an angle to get the stuff on the wall and spread it out, intending to go over the result with a larger finish trowel (knock down and smooth)
Problem: Looks like a Van Gogh painting in white! Very RUSTIC and wavy. I'm very slow putting on the plaster and working my way up or down the wall in sections. What are the signs in plaster that it is ready to get "knocked down"? Or is this something one doesn't do with a finish coat? You're supposed to put it on smooth?
Anyway, I went back over the waves and filled in the catfaces, and low spots. I thought I was getting good adherence with the plaster wall behind (which is a combo of places where I had already done 2 coats of repair plaster plus the old surface of the original wall left intact, but paint mostly removed).
Major cracks constantly appeared in the previous work as I moved to other areas of the wall to use up my plaster.
Should I have used a wood float to put on the coat?
Last, I keep getting black burnish marks on the high areas of plaster when I use the finish trowel. Why?
OK, can some experts weigh in on all the things I'm doing wrong in my quest to learn througn trial and error?? What should I do with this mess when I return on the weekend? Friend says "It ain't pretty." Sigh.
To the other poster looking for hair to add to lime in the US--try Virginia Limeworks. They have goat hair you can purchase. I used white.
