Nigel Watts
- London N7
My wife wants me to move the TV from our living room, where it is increasing being monopolized by the kids' W-box sessions, to the wall of our spare bedroom.
There are two problems I need to solve. The first is that the wall of the spare room is nine inch solid external brickwork which has been lined with polystyrene-backed plasterboard (the polystyrene, which is for heat insulation, is about two inches thick). Do I just use very long screws for the bracket or should I cut out some of the plasterboard, fix wooden battens directly to the brick and then fix to the wood?
The second problem is wiring. All the sockets are in the wrong place (ie not half way up the wall, in the middle). Three wires will be needed: mains power, UHF coaxial and hdmi for the X-box. I have been toying with the idea of surface mounted trunking, but concluded that there is no option but to embed the wires. A fused spur for the mains I guess, with UHF and hdmi embedded alongside. I have discovered that one can get hdmi wall sockets, but dont yet know to wire them together.
Finally, what might be needed in future? I dont really want to have to do this again. Should I add, for example, some cat 5 ethernet cable too?
