A
		Anonymous
Guest
Can you help? We have Victorian/edwardian pipes, with a back boiler which can be drained by a pipe on the ground floor. The stop cock on that (22mm) pipe won't close properly and there is an exposed outlet (which is rusty and threaded) from that stop cock which leaks constantly.
The diameter of the outlet (from the outside of the thread) is 40mm or 1 11/16ths.
Does anyone know of a stockist of "stop ends" for such an old threaded pipe? We have tried the local plumbers merchants, and they only seem to stock for new pipework.
If all else fails, I would like to block up that threaded pipe, until we can effect a permanent solution. A large cork, cut to size (buttered up with a grab adhesive) springs to mind, but if anyone has a better suggestion, I would be very grateful.
Ross
Ross
