I’m looking for a bit of advice on restoring Victorian pine flooring in a house we have recently moved in to. We’re trying to get the property up to a nice standard of finish whilst preserving as much of the period materials and features as possible.
Downstairs the floor has been an exposed wood floor for a long time and looks to have been previously treated (natural light pine colour), although it could do with some reconditioning. Upstairs the majority of the floors upstairs have been under carpet (darker/dirty appearance, with some boards painted, after raising carpets) and many are loose and have been cut etc., so more work is necessary here.
Unfortunately, the gaps between boards downstairs have been filled with some horrid silicone type filler, whilst the upstairs floorboards gaps are either empty, filled with dirt, or a brittle substance. Presently I’m just trying to scrape this out with hand tools.
Since several boards are likely going to have to be replaced with reclaimed stock, and other works to the house (e.g. electrics) could possibly damage a few more, I’m wondering what the best way forward is. Do I want to:
- Leave as much down as possible without disturbing, and then sand/treat etc.
- Or use this as an opportunity to ultimately raise the boards, remove rusted nails and condition the boards better, and then re-lay the floor. If this option is better, would it also be advisable to slightly reposition the boards to close or the gaps or just try to preserve the existing layout?
We’re going to pull a few floorboards up and have the joists checked out too before committing to the flooring, as I guess that could alter the course of action.
We’d like to tackle as much as possible ourselves as it’s a good way to learn the skills to keep the house I order, but obviously don’t want to dig ourselves into an increasingly bigger hole.
