My kitchen is located in the old Victorian laundry which serviced the whole estate. As a result the floor was engineered with a significant slope (to aid drainage) and I still have an original slate laundry sink which looks like it has had plenty of use.
Anyway, there is a large 'cupboard' (9' x 5') off the kitchen (laundry) which has a sliding frame inside that clearly was pulled out from time to time. I wondered what this was used for. Today I decided to lift the old rotten floorboards within the cupboard and found that the 'frame' is mounted on wheels that run along iron rails and the cupboard pretty much would slide out in to the middle of the room. Inside the cupboard and beneath the iron rails I have found a sunken floor upon which are mounted brick/iron 'ovens' each with an iron 'lid' in to which I assume hot embers/ashes were deposited to heat the cupboard. I suspect this was a drying room where laundry would hang when unable to dry outside.
Has anyone come across such a thing? Was this indeed a drying room or am I mistaken? I cannot think whatever else this cupboard was used for. The flagstones cleary show worn grooves that indicate the frame within the cupboard was heavy and frequently used.
I am going to install a non-destructve wooden floor above the 'ovens' but wonder if there is any significance to what lies beneath!
Alan.
Alan.
