chuckey
- wenslydale
I am just starting blocking up a 42" wide doorway (to turn it into a window) in a rock and rubble pig sty. Having lifted the flag in the doorway, and dug out about 9" of moderately hard soil, I have reached a layer of large stones, when I lift these, their holes fill with water. The water level is about 12" below the finished floor level. The bottom of the water is about the same level as the transition between the top soil and the clay subsoil.
Next summer I was intending to build a land drain around the building, but now is not the time to excavate deep holes in a field! The attraction of doing the rebuilding job is that the inner skin can be built in the dry.
The options I can see are:-
#1 build a sump to collect the water, hence dry the trench out.
#2 Leave the big stones (not really that big, say, grapefruit size), and fill gaps with pea shingle, rammed down, then build wall on top of this.
#3 Try to level bottom of trench and hammer in bricks on end into mud/clay so as to bring the bottom mortar course above the water level.
#4 Put the flag back and wait until next August.
Any other ideas?
Frank
Any other ideas?
Frank
