A neighbouring house has a ground floor window with a vertical crack through the brickwork below it. I was asked whether or not this was an issue but am at a loss to explain why the crack has occurred.
Now I've seen this one I've also noticed similar cracks on other properties (both brick and stone built).
The crack is only about three courses long, about 1-2mm wide and almost smack in the centre of the brickwork below the window. It goes through the bricks rather than following the mortar and doesn't appear to have affected the window frame itself (or internal plaster). It looks historic so I've suggested there's probably nothing to worry about but maybe get a structural engineer in.
Does anyone have an explanation for this type of crack? no other cracks appear above or around the window.
Any thoughts?
Any thoughts?
