Hi
We're in an Edwardian house and the 2nd floor (attic) chimney breast has had patches of damp since we moved in a year ago. We've had the flashings replaced and work done on the roof. We've now stripped off the plasterboard over the chimney breast to reveal the brick underneath (the outer walls are sandstone).
The opening is still there - see photo [edit - apologies for it being sideways: I've no idea why!] - and, after we'd removed several large bags of black mortar lining that had fallen off over the years, our chimney sweep advised that the chimney was pretty clean. Although we won't use it again as a fire, we plan to put in a cast iron fireplace (not original, but Edwardian).
Now, my question. The sweep has told us that there is no vent in the chimney. There is certainly no pot, and he says it has all been sealed up, and recommended we install two air bricks - one in the chimney and one in the back of the opening. Does that sound sensible? Our builder has said he would need scaffolding or a cherry-picker to insert an air brick in the chimney, which of course makes it rather expensive! If we put in a fireplace it will not be airtight, so does that mean we don't need the air brick in the opening?
We're keen to get this right and get rid of the damp, but obviously don't want to spend money unnecessarily. Advice very welcome.
