Hi
I have been looking at the forum for some time. It has been a really good source of information. Unfortunately, I am not experienced enough to offer reliable advice, but I hope that that changes in the near future.
For the past 10 months I have been working on a rubble stone and brick weaver’s cottage. We do not know the exact age of the house, but it’s probably from around the mid 19th centaury. As always, there was more work to do then expected, and we have ended up gutting the place,
Were possible, the Portland cement has been taken off internally and externally and replaced with natural hydraulic lime. The external walls on the inside have been replastered in NHL, using the guidance on the http://www.limestuff.co.uk, advice sheet. The plastering work was finished a week ago and we have been trying to let things dry out naturally. The internal temperature of the house is around 10 degrees C, without the need to use the central heating. However, there does appear to be moisture on the walls.
The property has a roof covering of traditional clay pantiles. Judging by the felt, it was last re roofed in the 1960’s. I know that it has been cold and damp, but we are starting to get white mould on the old felt and roof rafters. We have had some work done on the roof, such as leading around chimneys and replacing damaged rafters, tiles and felt. In addition, the internal walls of the roof space have been repointed, so generally, with all the plastering and pointing, we have been using a lot of water. We have not put any insulation in the roof as yet.
I am starting to think that I may have sealed up the roof void too tight. With all the faults and gaps, there used to be quite a few drafts. Some of the vertical brick joints did not have any mortar in them and you could see day light, now I think that ventilation was the reason. At the moment I have a dehumidifier working away in the loft and it is collecting a lot of water.
I am anxious to make sure that the house breathes properly, including the loft. I was going to fit a positive pressure ventilation system ( http://www.twistfix.co.uk/products/anti-condensation/nuaire-drimaster-product.html ) , but there is no point in doing that when the unit is sited in a loft, which has a tendency to damp. The other option is a whole house ventilation system such as the MANI3000 .( http://www.manrose.co.uk/specifications/manivent.pdf ).
To my request for advise please:
Should I turn the heat up to aid the drying of the lime plaster?
What is the best way to achieve ventilation in a loft roofed with traditional pantiles? “Santoft” make tile vents for the modern pantile, but it does not look suitable. There is little air coming from eaves and the tiles rest directly on the walls.
Has anyone experience of the whole house ventilation system or positive pressure ventilation system?
Thanks in anticipation.
Mark M.
Mark M.
