Well, after the great response to my question about gutters, I'm back with a few more questions about... damp (surprise, suprise).
We have a 17th century timber framed farmhouse in Cambridgeshire. Most of it has had a
cement render on for the last 50-60 years.
I've got a number of damp problems in the house, and I'm looking for some extra opnions
on what might be causing them.
1. Damp problem number 1
This problem is in a 17th century brick 'extension' with three external walls, one
with a cement render outside, two with (masonry?) paint on the outside. It has a large inglenook fireplace
with a bread oven. We've removed the decrepit old wood-stove and replaced it with
a new wood-stove. It also has quarry tiles which I think are probably set in
concrete, and were probably done about 40 years ago.
We've improved the heating in the house so all the rooms can be kept at a permanent reasonable temperature.
At some point in the last 10 years, the previous limewash was covered in what appears to be some kind of standard paint. In patches around the bottom of the wall, the paint is bubbling up and flaking off. Where the paint has flaked off, there is a white 'fluff' which I believe is
salts leaching out of the brickwork.
There is a particularly dodgy bit of west-facing wall where a pipe leads through to an outside
tap (see picture) but there are several places where the paint is flaking off.
Outside, the west-facing wall was covered in climbers. I've taken all of those
out, have dug out a lot of the soil next to the house, and have fixed a massively leaking
waterbutt.
I've unearthed two drains which were concealed under planks for some reason,
and have removed soil which had fallen into the drains.
These drains turn out to have U-bends - so that a certain height of water is kept permanently in the bend
by the house. I presume that this is to stop smells from the drains, but I wondered
whether it might be causing damp problems. However, I can't work out any way
to check whether there's a leak in the drains. Even cleared and with a drain snake down them, the drains seem to be rather slow to drain away if I chuck a bucket of water down them.
To be honest, the place is damp enough that it's hard to work out whether there
are any extra damp bits which might signal a leak in a pipe or drain.
My plan is to remove the paint on the inside of the room, leave it to breathe for a while, and then limewash
the room.
If that goes okay, I'll also remove the paint from the outside walls, repoint with
lime where necessary, and replace it with a limewash. (Pending okay from CO)
So the questions are
- does removing the paint sound sensible to everyone else?
- does this kind of U-bend drain seem reasonable? is there a way that I can check if it might be leaking?
- is there any way to check if a pipe is leaking slightly in a generally wet wall?
2. Damp problem number 2
This is a mysterious damp patch in our dining room. By the chimney (now blocked up),
the paint and plaster is bubling up and coming away. There aren't damp problems
elsewhere in the room, and this room still has its original brick floor.
Any ideas what caused it? (Is the chimney leaking? If so, what on earth do we do to investigate a blocked up chimney in the middle of the house?) And what should I do to repair it? Should it be replastered using lime? I doubt
that much of the rest of the room is done in lime plaster. I'm pretty sure it's concrete underneath, anyway.
Again, the room can now be kept at a reasonable constant temperature.
These are just the first two of a list of different damp patches in different rooms... 8)
What do people think?
Thanks!
Hatster
waterbutt.
the room.
Thanks!
Hatster
