electricianid
- Suffolk
I am confused about the recommendation of a vapour barrier between the plasterboard (or equivalent) and the insulation in a typical dry line system or come to that in a ceiling. I understand that this is to prevent warm humid air condensing in the cooler insulation layer.
My queries are,
1) If there is a layer of gypsum plaster applied to the PB perhaps with a few coats of semi gloss paint, will this not act as a vapour barrier alone?
2) If insulated PB is used (plasterbaoard laminated with say 30mm of insulation) then obviously it is not possible to include a vapour barrier in the recommended location, what then?
3) If PB is fixed onto a stud frame insulated with Celotex why would a vapour barrier be necessary, Celotex seems to be pretty waterproof (the foam part and the foil) so if any condensation were to occur between the insulation and PB even to the point of saturation surley it would just evaporate back into the warm room (path of least resistance)?
4) How would one go about fitting electrical boxes which may be 40mm deep, 12mm in the PB leaving 28mm to be buried in the insulation whilst maintaining the vapour barrier, ditto for downlighters in the ceiling?
5) On removing the 35+yr old ceiling in my house the fibre glass insulation and timber were completley dry (to touch) with no evidence of decay, despite there not being a vapour barrier, there would have been lots of humidity in this time as the only heating was gas bottle fires.Any ideas as to why this was not subjest to condensation?
6) Would it be acceptable to somehow enclose the pieces of insulation in a waterproof layer instead?
All of the intended drylining/ceilings will include a vented air gap between the stud wall/insulation and the external solid brick wall, studs could be of either timber or metal.
Apologies if I'm just being dumb, any opinions welcome.
My queries are,
