atlasfever
Hi All,
Hoping for some feedback:
As I understand, for a single skin brick wall insulation, you can use a rigid insulation bonded to a plasterboard. And, I have read that you need a vapour barrier that is bonded between the insulation and plasterboard.
It was suggested that I use GTEC 27mm XP, which does not have this 'official' vapour barrier. This is about half the cost of supply, than GTEC K, which definitely has a vapour barrier. I called up GTEC, they said that you can only use the XP if you're insulating a cavity wall, but if you're insulating a skin brick wall, you need the 2nd one. Technically, the rigid foam does provide some moisture resistance, 9MnSG, but the better one is about 100 MnSG. I have no idea what this means, only that the folks at GTEC said that the natural moisture resistance of the foam is not enough. (FYI: British Gyproc makes the same, except it's "Thermal Board Plus w/o vapour" and "super" with vapour barrier.
I feel that I need to do what's suitable in the long term, not what's cheap. But, I have a habit of doing the 150% level of perfection, when maybe you just need like 85% if you know what I mean. So, any feedback on this? My gut tells me to pay up and do the proper one, with vapour barrier (and by gut, I mean a thick document from english heritage for instance, a document from the council office and conversations with insulation providers
Thanks.
Thanks.
