wobs
- Hull - there's a nip in the air.
Next major job at Wobs Acres is to tackle the Utility room*. This is a bit of a strange order, as I would normally prefer to do it last, but 1st born's bedroom is directly above, and her's is the coldest bedroom, so......
The basic plan is to insulate the ceiling of the utility room with a Celotex type sheet (its currently got some polystyrene sheeting on it). We'll probably strip back to joists and start from there. Limited to about 2" of insulation on the main ceiling here.
But the rest of the room is a bit more open to question.
We need a new window and back door, so as you'll see in the pics, we'll probably have to raise the floor (and level it off first).
The wall under the window is currently single brick (rest of the house is double brick).
Just about all the people on our row of houses have knocked through their utility room as far as I know, but we wish to keep the pantry etc, and if its the only one left on this row of houses, it just reinforces our resolve in this.
House is a 1900s house. As you'll see the wall has been pointed with cement, so lime cement is unlikely to happen. The floor is currently dry, but we see moisture come up in the middle in winter. The room has a sheila maid on the ceiling which seems to dry clothes quite quickly even in winter, probably due to the large amount of "ventilation" (or draught) (note the double vent in the wall)
Potential options for single brick wall:
Builder suggested sticking Celotex to it
A neighbour has lined there house with metal frame mounted Celotex
A second brick layer
Something else
As you can see, the floor needs levelling off, but we will probably have to raise it to bring it above the damp course. This may raise it above the toilet, just to make it interesting, but it maybe a good idea to insulate the floor while we're at it. Any suggestions for this would be helpful.
Basically, any advice would be welcome, as its a bit beyond what I'm used to doing.
* We call it a Utility Room, but my parents call it a scullery. Not sure of the distinction, but given what we use it for these days, I think a scullery seems a bit wrong.
Something else
