Lynn
- Wisconsin USA
Sorry if USA restoration problems are out of bounds on this site, but I was referred by one of your own. So my issue is color. I have some pictures on the web to help in this discussion:
http://web.mac.com/chakoianfamily/iWeb/Site%205/Photos.html
I start the pictures with the back of the place that I worked on last year and pretty much have completed. I used a cement-lime mix to patch the cracks in the stucco. My understanding is that at this time period in the US they used cement for stucco. I then painted it with a lime wash with a bit of pigment in it so we don't go blind in the midday sun. I rebuilt the window trim/sills because it was covered a decade ago with aluminum and it was a very bad job. I think they used a whole tube of caulk on each window, so there was a lot of wood rot, some carpenter ant issues and...well it was a big project. Having made all my mistakes and experiments on the back, I'm now on to the front.
I am doing the window frames in the same cream color, screens and storm windows in a soft grey, and inspired by a member here I have painted the sashes brown (upstairs so far). You might be able to see the difference in some of the photos. The window on the upper left needs to be rebuilt. I hate to think what I will find when I take off the aluminum from the first floor, but that will happen soon.
So the main question, now that you are oriented...I have grown to hate that blue color that is on the metal work and on shutters (taken down for the moment) on the upper floor. So what color might fit in? A friend is trying to persuade me that Vertigris would be the thing...although the idea of wooden shutter being aged copper color seems odd to me. So any ideas are welcome.
I'm also encouraged by others to take the stucco-like material off the bricks around the front door. I think it is a good idea, but suspect it might destroy the brick as we try to expose it. Cold chisel, brushes...sounds difficult. The brick ought to be a deep red/maroon color and that would offer a bit of detail to the building.
Also I'm looking into having the small roof over the front door redone so that the drainage doesn't hit the stucco. I'm not sure how to handle it since there is no where to run with the water...Georgian gargoyles?
Sorry so long a post, but these projects get complicated don't they?
