gothiceye
- Shropshire
OK. Help needed fairly urgently please....
We are looking to make significant alterations to the bathroom in our property since a leak has made it necessary for us to remove the existing shower cubicle and the modern plasterboard wall which seperates the bathroom from the spare bedroom. I emailed the council to check whether such work would require LBC, and found out that moving even modern plasterboard walls will need LBC as it is altering the structure of the property.....
However, we have already needed to make investigative holes in the plasterboard to determine the cause of the leak, and have made another which has revealed the site of the old upper fireplace. Also we have already removed half of the plasterboard wall on the landing, as we thought it would be OK as it wasn't an original feature
Realising our mistake far too late - is there any way that we can apply for retrospective consent for the work we've already done? Will it be allowed or will we have to return the property to its original state?
Am really confused and worried about the implications of this, as I think I read somewhere that it was against the law to make unapproved alterations to your property, I just mistakenly believed, from a dicussion that we had with the conservation officer soon after we moved in (and way before we knew that any of this would take place) that this only affected the original structure.... Any help gratefully received........ :shock:
