Can anyone advise on the cause/solution for crazing over my finish coat. This is my first attempt at lime plastering a finish coat although I do have lots of plastering experience with gypsum.
Mix: 1:1 lime:silver sand (kiln dried block paving sand), no water added.
Background: Dry devil coat (completed about 3 months ago)
Preparation: Wetting of surface about 6 times to ensure a consistent colour across the wall, with no 'standing water'
Application: two tight coats perpendicular to each other, sponge floated second coat, third coat applied into this and then trowelled off in two directions. Lovely finish (crazing aside) - perhaps too overtrowelled if anything.
I applied the finish coat on Monday (now Wednesday), but am now finding a fine crazing in some areas. These are particularly prevalent around the edges of the walls but there is a patch about 20cm square offcentre from the middle of the wall.
So my questions are:
1. Is this crazing primarily caused by shrinkage? - i.e. should I make sure I have a more damp background for future walls.
2. The crazing is hardly noticeable to the touch and I've been pushing it in as it's been appearing - is it likely to get worse?
3. What aftercare do I need to apply and for how long? - I've given the wall a light spray morning and afternoon. I'm off on holiday from Friday for two weeks so don't won't to come back to a jigsaw finish across the whole wall.
4. If cracks do appear how best do I deal with them? - fill with lime putty?
Any advice gratefully received.
