ukstations
So a few weeks ago I posted lots of pics here of my property where I had
torn down the interior plaster render, much of which had been put there after
previous damp proof re-rendering.
Anyway, for anyone interested, I have now removed some joists and discovered that
all of the SOIL PLATES have rotted away to a large degree and so have decided to replace ALL
soil plates on the ground floor throughout the house.
While undertaking the above, I also discovered that whomever last maintained the brick airvents
actually removed several bricks in strange places in the foundation to allow for air holes internally way below
exterior ground level despite the brick vent being located 4 to 5 bricks high externally. I want to state that this solution was poorly executed as the greatest amount of rot and damp have been found around these holes. I have since decided to block off these vents and instead, put floor registers in whatever new floor I decide to lay. I hope this will work to allow for some underfloor airflow.
Has anyone else done this?
Separately, I suffer from rising damp on internal walls. I have discovered that the entire concrete base under the joists at ground floor level is always damp. I am not sure what I should do about this but I am tempted to
ignore and just ensure that all joist ends are protected for the future and that my decorating account for the fact that the walls will be forever damp up to about 2 to 3 feet off floor level internally.
ps. I bought the haynes manual to victorian homes and it is just PERFECT!!!
Regards
C
Regards
C
