Just thought I'd update on my dodgy chimney breast lintel for those that are interested.
During work to what will (eventually!) be the dining room we looked carefully at the fireplace. The chimney on the roof had been rebuilt when the new roof (slate) was fitted and the capping removed to allow the fireplace to be used once again.
Clearly the fireplace was a later addition, didn't fit well with the rest of the room and had reduced the original opening significantly. So with LBC we decided to replace it with a stone fireplace, something which (according to a previous owner) had been removed some time ago and replaced with this monstrosity:
The tiles on the hearth were original, as the brickwork (cement mortared) was built directly ontop. It was my intention to reuse the tiles for the new hearth but despite very careful removal we lost too many to be reused.
On dismantling the fireplace we were left with this:
which became the subject of a previous post as I was particularly concerned about the tiny bearings supporting the massive stone lintel above the fireplace opening.
So after consulting the building control officer it was agreed that some additional support was needed. So the brickwork was removed and a concrete lintel inserted. Not strictly historic but safety took precedence!. It was unnerving to say the least seeing the large stone lintel 'floating' for a short point before the lintel was inserted, the bearings either side rebuilt and support put in between the stone and concrete lintel:
Once in place and with sufficient time to set I was then able to fit the new fireplace and hearth:
Many thanks to GeoffP for letting me use his stone fireplace design and for his contacts to get it made.
Let me know your thoughts.
