In a part of the house that is probably from 1840, with 40cm thick brick walls, I have floors that are level with the outside, and full height french windows. The only sub-floor ventilation seems to have been cut in the last 30 years just outside the french windows. The timber is all in very good condition, considering it has been covered up for about 30 years, but there is some rot in the oak behind the french windows. I am beginning to wonder whether these vents were necessary and whether they have actually caused the rot, since the vents are in the ground and probably attract rainwater. There is generally quite a large space under the floors.
There is also another area which has rot after all these years, but that is next to a raised level floor in another room.
I had been planning to cut above ground vents in the walls with airbricks and tunnel down at an angle to end up below the floor to ventilate, but I am beginning to think that would be a waste of time. Does anyone have any views?
Either way, I am looking to put new flooring down over the hotch potch of lovely old oak boards mixed with dodgy newish ones. Ideally, I would put a layer of oak boards over an insulating underlay. But I think all insulating underlays are also vapout barriers... again, any views would be greatly appreciated.
