I have a lower room in an old 1880 stone cottage with a thin concrete floor directly on bare earth. This contributes to a damp issue and I have just stripped all the plaster off the walls, repointed with lime mortar and am now breaking up the concrete floor prior to putting a limecrete floor down. The room was actually built onto the side of the house in about 1920 and I've just found that the footings for the original outside wall of the house (which is now the inside wall of the lower room) are shallow, on bare earth and nowhere near as deep as I need to go to lay the limecrete floor.
If I break up the rest of the concrete floor and dig the soil out under the floor to lay the limecrete, can I be causing problems with the wall with the shallow footings? Do I need to underpin the wall? The house is built on a slope and I haven't found the footings for the other three walls yet so they hopefully will be deep enough.
