Steve London
- London
Hi
Can anyone help, I have a victorian terraced house
I am considering fitting some type of underfloor insulation on the ground
floor to cut down on heat loss through the wooden suspended floor.
I would prefer to fit the insulation from underneath the floor
(there is a gap under the floor boards where it is possible to crawl along, although sheets would need to be cut down due to the restricted space) rather than having to lift the floor boards & re-fix them (I would not cover the air bricks to allow free air flow to the joists etc.,)
My questions are:
1. Would you recommend insulating this type of floor & if so, what
type/brand & thickness would be recommended
2. Should there be a gap between the under side of the floor boards &
the insulation, if so what size gap would you recommend
3. Please advise whether a fire retardant grade is recommended, the
area to be covered is approx 40 sq metres in area
4. Is it ok if the insulation comes into contact with pvc covered electrical
cables & copper central heating pipes?
I would be grateful for any advice anyone can give especially if they
have done anything similar
regards
steve
My questions are:
regards
steve
