tumbledown
- Suffolk
Now that my differences with the CO have been settled and she has seen the error of her ways (well, thats my version of events anyway), I've turned my attention to the floor.
We have removed the concrete floor to reveal a much older floor, which is brick in one area and pamments in another. Unfortunatly, its not in very good condition and beyond restoration. I've discussed it with the CO, and she agrees it should be covered up, but with a breathable floor. The proposal is to use rammed chalk over the existing floor and finish with pamments. The Building Control Officer is also okay with this plan.
However, we have been concidering underfloor heating. The problem being, is I'm not sure it is really suitable in this situation. The main reason I want to do it is to cut down the number of radiators. One problem is I don't really want to raise the level of the floor very much. But I guess you need some sort of insulation to stop you just heating up the old brick floor and getting much benefit from the UFH. This is a timber framed house built in 1550 (ish) and so existing bricks are just laid straight on clay floor.
I guess my questions are:
1) Would the CO object?
2) Would it be an efficient source of heat?
3) Would you recommend gas/water system or electric?
4) What would be the minimum depth of the finished pamment floor be in
relation to the existing brick floor (ie, taking into account some kind
of insulation plus UFL, plus chalk, plus pamments?
Any comments, advice etc would be most welcome!
