Has anybody got any experiance with fitting underfloor heating?
My current floor is concrete with a DPM and with a high local water table moisture is being forced up the walls. For this reason I would like to replace the floor with something breathable.
My heating system is also on the way out and I'm thinking strongly about fitting a heat pump to heat the house. Heat pumps work best with under floor heating so I'm thinking of solving both problems in one go.
The only option I've heard of so far is to use LECA mixed with lime as a base to insulate the floor together with lime screed to fix the under floor heating into on top.
I am sure there must be other options available (hopefully a little cheaper). Any good suggestions on solutions or websites to look at?
Cheers, MdB
Cheers, MdB
