I saw your response Gervasse to Geoffs topic “New Walls butting to old” and wondered if you or any other building engineers out there might be able to advise me on this.
My old Baptist chapel home built around 1817 is a two story gable fronted building of nine inch solid brick construction comprising of an open plan ground floor with first floor balconies on three sides complete with box pews.
Recent exploratory work involving the careful removal of some original T&G timber wall panels at balcony level leads me to believe that the gable end frontage and entrance is a Victorian extension. This frontage which has a stucco façade based on classical designs of imitation stone blockwork and arches extends into the original chapel by about six or seven feet creating and entrance lobby and an enlarged balcony above.
My concern is that this extension does not appear to be keyed into the original building, in other words the new Victorian brickwork appears to finish flush against the original Georgian brickwork with an obvious vertical un-keyed join straight up through the building (at least as far as I can see with the panels removed).
The original building has been standing for at least 190 years and I estimate that the Victorian addition is about 130 years old. From the outside the building looks decievingly like one structure with the victorian structure having its original render extending around the sides of the building to cover the join. There is also a common and unbroken roof covering the two stuctures with matching internal rafters and wood plank ceiling.
There is no evidence of any structural defect other than an area of about 2 or 3 feet square on the Georgian side of the “join” on both sides of the chapel at balcony level, where a good few stretcher bricks are missing (hidden for 130 years behind the panelling recently removed) and presumably left out by the original builders. I intend to replace these missing bricks but should I consider keying in the replacement stretcher bricks between the Georgian and Victorian structures and should I be concerned about the majority of remaining original un-keyed structures.
