overlander matt
Work is progressing up at roof level right now and has thrown up a couple of problems that need solutions in the next couple of weeks while we have the scaffolding. I've included the followings photos for reference:
Problem 1: Rain water drainage.
There are three sections of the roof that require a better drainage design than at present. The front and sides of the roof have lead gulleys that empty to the rear so as to avoid unsightly guttering on the front of the house! The rear of the roof empties into standard cast iron guttering. Previously, water from the side of the roof, drained via a 3" lead pipe that emerges through a wooden cornice into a 4.5" gutter that also took the water from the rear of the roof. A short 2.5" downpipe on the right side of the gutter then dumped this water on the roof below. This seems a bad design because the water from the lead pipe tends to splash the wooden cornice and surrounding brickwork leading to rot and brick damage and I am looking for an alternative... How about a downpipe with a hopper directly below the lead pipe which can accommodate the gutter outlet too? This would then avoid any discharge onto the roofing below.
There is an extra consideration for the drainage - the rainwater from the front of the house is channelled through a box gulley in an attic bedroom where it is then also dumped onto the roof below. This feature although a bit of a novelty has caused a fair bit of damage over the years. We have permission to reroute the water through a plastic pipe and connect to a down pipe at the back of the house. I'm keen to see whether all 3 can be connected to a single downpipe running just below the side and rear gutters and how to make this look tidy. I was thinking about a 4" downpipe running up to a rectangular hopper that would catch the rainwater from the side and rear. As the outlet from the front will be lower and probably off to one side, I wonder whether a branch off the main downpipe would look ok and whether to have another hopper? It doesn't sound quite right to me but am not sure how best to collect three outlets into one downpipe...
Problem 2: Fake/wooden corbel detail.
With the gutter removed, it revealed a section of wooden fascia that looks like the adjacent brickwork corbelling! I'm unsure why anyone would have done this. Presumably the brickwork was damaged at some point and this detail was never restored. The timber is not in great condition but not so bad either that it must be replaced. I have no idea what I should do with this - reinstating the brick detail would be a lot of work.
Any ideas on the above dramas would be much appreciated.
Thanks,
Matt
Thanks,
Matt
