dinglem
- Staffordshire
Hi all,
As detailed in another thread a while back you may know that i have recently opened up my original inglenook; it has cleaned up very nicely and i am now considering the practicalities of having an open fire. It is very large and standing in the fireplace itself and looking up, you can clearly see that at the top of the stack (i.e. above the roofline) the chimney splits into two; the vertical column leading up to the top of the chimney above the roofline being split by a single layer of bricks with a 'V' shaped dividing piece at the very bottom. There is room on top of the chimney for a pair of pots, but currently there is only one. The second is capped and sealed for some reason??
I am assuming that if i open up the second vent and add a pot to this then the overall draw will be improved? Is this correct?
I will obviously therefore be changing both pots so i have a matching pair. Would fitting taller pots at this time serve to improve the draw even more???
Does anybody else have something similar? I am wondering why the second pot was removed and capped in the first place??? Thoughts?
The second chimney stack at the other end of my house has two pots (front room and bedroom fireplaces sharing this chimney) so two pairs of pots will actually prove easier on the eye...
Cheers Martin.
Cheers Martin.
