Zebra
- St Albans, Hertfordshire
Dear all,
This summer I completed my French drain arrangement. The house is around 300 years old. Along one side the ground level is about 300mm higher on the outside than the inside, and I dug a trench right up against the wall of the house, since the land on the other side is the churchyard, so I cannot dig a trench further away. Neither can I leave it open because of the risk to the public. (The church are fine with what I've done.)
So it's a trench say 300mm wide and 450mm deep (to the depth of the foundations) with a drain pipe in the bottom, which drains away to a soakaway. The trench is lined with geotextile to prevent dirt entering it, and filled with coarse gravel. The geotextile is wrapped over the top, with a shallow layer of pea shingle on top of that. The brick behind is bare. (It's a 9 inch solid brick wall.)
Now I've had a architect do a specification for me for the woodfibre-based external wall insulation which I want to use. He's consulted with an expert in the application of external wall insulation to historic buildings, so I'm inclined to consider his suggestions seriously. He says that this wall needs to be protected from groundwater as much as possible, and thinks that the wall will not dry externally through the gravel, only internally. He therefore recommends applying a bitumen coating externally to the brick, then a drain membrane system followed by a 40mm layer of XPS (extruded polystyrene foam) insulation, then a Baumit render. This layer would continue from the bottom of the French drain to 300mm above the external ground level, where it would then join, with a drip bead, to the vapour-open woodfibre insulation system above.
There are a few words in there that ring alarm bells with me. Applying bitumen to the brick? Would anybody have any views on whether bitumen would damage old brickwork?
What do you all reckon about having a non-breathable coating on the walls to above ground level, then switching to the breathable system? He's not recommended non-breathable materials anywhere else in the building, but feels that where the wall is below ground, the risk of ingress of ground water is more significant that the drying afforded by the breathable finishes.
Any views?
Any views?
