senorjackson
We are in the process of purchasing a Victorian house (1895) in the East Midlands. The survey has highlighted damp in the walls of the ground floor and has suggested the usual injecting of the walls after taking off 1 metre of plaster on each wall. The floor of the lounge and dining room ( in each room the damp is deemed to be high- in survey, levels of damp detected went off the scale) have solid concrete floors though I doubt these are an original feature. I don't know whether they have a dpc membrane. Might it be that damp in the floor, unable to escape, is spreading to the walls? Other points to be taken into consideration:-
1. The house has been vacant for at least 6-9 months
2. The back of the house backs onto the road. I don't think the internal level of the house is much higher than the road itself but can't be exact.
3. House has been deemed to be fine apart from this issue.
Having read through the forum, I've posted this as I haven't been able to find a precise answer to solve the damp. I would gladly welcome any advice on how to treat this successfully, as I am unsure if we should move in and see how things go or look to try to sort things out before we move in. Is there an easy answer?
Many Thanks
senor
Many Thanks
senor
