ElectronicFur
- Monmouthshire
From the other post on sash window restoration costs:
Any ideas what the difference are when the sash windows are transom and mullion ones?
All my sash windows have transoms and mullions. I need to restore them all at some point. Some have unfortunately been painted shut, some with big gaps, so very draughty.
Window example here:
Also does anyone have any idea why this bay has pulley wheels above the sash windows? In the photo you can see two of the brass pulley wheels that are above the windows, no idea what they would have been used for. It's only this particular bay that has these above the windows.
Feltwell said:You remove the staff beads first, which are - when looking from inside the room - the strips of wood around the inside of the sash box frame that hold the bottom sash in place. After that you can take the bottom sash out into the room. Then you remove the parting bead, which as the name implies keeps the 2 sashes apart, and the top sash comes out, again it comes out into the room. All that work has to be done from the inside anyway. The sashes can then be taken away and restored anywhere - the box frame can be cleaned up from the inside, it's really only at this stage that having external access is useful at all, as you strip the paint off the outside face of the sash box - but this isn't much and you can do it easily enough by leaning through from the inside.
