Lady_Mari
- Up a hill in Suffolk
I'm not sure if I am in the right forum as altho my cottage is elderly much of the original fabric has gone & repairs made in the '70's include two modern block extensions, solid concrete floors, concrete roof tiles, concrete render painted with Sandtex & (dare I mention) upvc windows.
Needless to say, it is not a listed building.
I think I have read almost every post in an effort to find answers to my most immediate problem which is basically on the only wall left that has it's original oak timbers.
The back (North) wall had an area of blown cement render. We have removed this & uncovered some very wet oak beams, much of the wattle & daub was wet & crumbly & fell out. The render had been attached to expanded metal but this has either rusted or been eaten away - (by the lime in the mortar ?)
After a few weeks of exposure the oaks have dried out & all but two are pretty sound.
We have taken advice for repairs & have two different methods suggested, we need advice as to which option we take.
First builder said will use traditional method & remove remaining concrete render, replace rotten oak studs, fix oak laths & lime render onto these. Sounds great but expensive - between £5 - 7k. (& can't start for months)
Second builder is currently renovating cottage next door & says will also remove remaining render but batten out from existing oaks to create cavity with air vents top & bottom, with membrane, fix expanded metal to apply modern render & will be much cheaper. He says this is how all modern timber framed houses are done these days.
Cost is a serious issue for us & this wall is the only one left that has timbers, the other walls are either rendered block work or painted brick.
Can anyone here offer some advice please.
