Feltwell
- Shropshire, England
What are the best / worst (depending on your point of view) bodges that everyone has come across?
As I mentioned on another thread, my parents have just bought a bungalow with a conservatory which for some reason a previous owner thought needed a Rayburn cooker in it. So they cut a hole in the polycarbonate roof for the flue. A hole that started out the same size as the flue we guess, but ended up about 6 inches bigger.
Just to make it better, the flue stopped just above the roof, and just under the (plastic) guttering for the main house roof. Which melted and so convieniently pours the entire roof's worth of water through the hole around the flue every time it rains.
A friend of mine bought a 2 up 2 down terrace a while ago, that had had the wall and chimney breast between the front and back rooms removed. But, in the loft, the chimney breast remained. Still, never mind, the cautious DIYer responsible for this particular feat realised the dangers of a ton of unsupported masonry sitting directly over their sofa, so they carefully chiselled some brick out of the sides and inserted 2 pieces of 4"x2" screwed to the ceiling joists to support the entire remants of the stack.
Good eh?
Good eh?
