Footdoctor
Hi All.
This is my first post so bear with me if I haven't put it in the 'right place'. :|
I am currently renovating a 18thC cottage in W. Yorks and am not sure how to dry out the cellar.
The cottage is on a steep hillside and the rear wall of the cellar is actually above ground.The space has two rooms but is irregular in shape as it was formed by 'squaring off' section of the hillside.
There is a small window in this rear wall which has been boarded over some years ago. I have wedged this partially open now in order to increase the through draft and it is not massively damp but needs to be dried out further to be of use.
As the space is solid stone with one small area of 18" thick wall, I wouldn't have thought it is suitable for modern tanking methods.
The walls are irregular and unsuitable for rigid lining. I am keen to utilise this space and would welcome any suggestions, other than using a dehumidifier indefinitely.
Cheers
The Footdoctor
Cheers
The Footdoctor
