Andys
- At the seaside in Hampshire
We've had a nibble at our timber frame repairs - this should get the neighbours talking.
I think we'll leave it for as long as possible to let the wood weather-in but I can see we may end up begging the CO to let us stain the new bits black to match the rest of the frame. I think it would be a shame to do that to nice new timbers but maybe it's better than having the house look like one of those unsolvable wooden puzzles.
Here's the joint between the Girt(?) and corner post with the decay cut away. It's reassuring to see how decent the wood looks after about 400 years.
The CO let us replace the diagonal brace in its entirety when it turned out to be a replacement bit nailed in place with no attempt at tenons and decay on all sides. I was spared a load of rebuilding work as the infill panel decided not to fall out, which was nice
The levitating brick infill panel was actually quite firmly supported by the layers of lime plaster, cement render and the bedding mortar of the previous owners' insulating blockwork on the inside. The little wooden props were there so I could still sleep at night.
Finally here's the hole which makes its way diagonally through the tie beam. It seems to be a natural feature where a branch grew in the original tree, which has then rotted away
I've a bit more to do, mainly encouraging the thin layer of cement over-pointing to fall off, revealing the original lime pointing. Next year it's the other end of the wall, where the corner post nearly reaches the ground, then the year after maybe we'll get the cill plate done....
