dandrew
We have an 1867 Victorian villa that has recently had to have some dry rot treated which involved replacing about 1/3 of the floor boards in the hall. The hall floor (a suspended timber floor) had previously been sanded and stained by previous owners, so we now have a mixture of old pine boards and new pine boards. Although I could sand down the new boards to make them equal height with the old boards, and then stain them to match, I've always had a hankering for a geometric/encaustic tiled floor. If I were to tile the floor I understand it should first be boarded over with 6mm plywood and then tiled using a flexible adhesive. The tiles are about 10-12mm thick, which combined with the 6mm ply would result in an 18mm step between the tiled hall and the untiled rooms off it. Is a threshold strip the usual solution to the uneven heights or are there alternative solutions ?
