I am now (finally) getting into the final stages of my current house restoration, and am thinking about the next property.
In a village not too far away stands this long unoccupied cottage. It was originally part of a longer terrace of 3 cottages, but the first 2 were demolished some years ago and only the ground and first floor frontage survives (they have been infilled to form a yard area with attached garage)
The render (no doubt a cement render) is still in good order and shows no sign of structural cracking (certainly nothing like the structural cracking that was demonstrated at the SPAB homeowners course I attended!). That said, the front elevation is nicely bowed...my thoughts were that this is possibly historic settlement- character- rather than a sign of impending collapse.
The property has been empty for many years, possibly knocking on 10 years, hence access points have been bricked up to stop squatters. The 2 upstairs windows have no glass left, so the rooms are open to the elements.
From this view taken from a nearby hill you can just make out a small tree that is growing out of the gable end wall by the chimney where some roof tiles have slipped off- this has caused a section of the upstairs ceiling to collapse, so may very well mean a lot of rotten timber inside.
My thoughts are that this property does not have much time left before it becomes a complete wreck, but is still quite saveable at the moment (maybe not the castle-effect bits though- they really are awful). It seems that a new roof structure would be needed, plus works to repair rotten flooring/joists inside (as well as handy things like doors, windows, electrics, heating, plumbing etc).
Apart from the first major hurdle of contacting the owners and seeing if they want to sell, then getting an inaccessible property valued, I am a bit worried about the issues of returning such a semi-derelict property into use- with regard to planning and building regs.
Do any of you have any tips or advice from experience on these sorts of projects at all?
Many thanks
Many thanks
