When building a new porch at the back of our house in the summer, we discovered that the underground soil pipe was damaged and had some of it replaced with plastic. I'm just getting ready to do the rest - the section from where the above ground stack goes into the ground to the new plastic bit further downstream.
I've dug down and around and apparently someone previously thought this was acceptable:
That's a yoghurt pot that has been pressed into service to direct the flow of the contents of the soil pipe into the clay below ground pipe which has been replaced and doesn't quite line up. The collar has been broken off (the right angle angle bit itself has just been butted up the clay further along). This was all cemented over so you couldn't see what was going on, but there's quite a bit of liquid not going into the drains. The whole lot is coming out and will be replaced with plastic.
I'm quite pleased to have got the top bit of the cast iron soil pipe down in one piece and am going to press all of it back into service. There's a hole in the section that is above the roof, but being as how this is vent only, I'm going to have a go at repairing it - probably with a bit of copper epoxied over. Has anyone got any suggestions for cleaning up rusty cast iron soil pipe and repainting? Should I just Smoothrite the whole lot?
