Feltwell
- Shropshire, England
Here at Feltwell Towers, whilst it's a reasonable size house, the family bathroom is tiny - just too small, it's long and thin, with quite a narrow bath with a loo squeezed into the gap next to it. Narrow, short baths are not a natural match for me - I am neither!
Apart from an external extension to the house, the only possible way to create more room is to borrow some space from our en-suite bathroom to create an L shaped family bathroom - it still won't be huge but it will be much better than it is now, and whilst the en-suite will be a little tight as a result it will still be OK.
However - to do this the wall between them needs taking out and a new stud wall building further over. It has to be a stud wall - it's suspended over the stairs - but it needs to be as thin as possible, as every inch of space in that direction will count in both rooms.
I tend to over-engineer most things, and usually for a stud wall I'd be looking at a frame probably made of 4"x2", so with plasterboard each side a wall of around 5" thick - but this time I want go thinner.
Both sides of this wall will be tiled with a shower on them, so the wall surface will be aquapanel rather than plasterboard. The wall will be about 10' tall x 5' wide - one side fixed to the solid outside brick wall of the house, the other side fixed to an existing stud wall that runs parallel to the outside wall.
Turning studwork round to be thinner side on just doesn't seem right, but I could double up the number of studs - or the other thought I had is to make a steel frame in-situ, I can make an outer frame and weld uprights and noggins into it. I'm just worried about "bounce" in the wall - whatever is done needs to flex as little as possible, whilst also being thin, two opposing priorities! It also has to accommodate pipes and a cable. It won't be load bearing.
Any bright ideas?
Any bright ideas?
