iansale
- Manchester
Hi all, new member on here. We have recently bought a detached Victorian house, recently well renovated however struggling with cold issues. Even with the full heating on full blast the main living spaces struggle to get above 12 degrees.
I got hold of a thermal camera and using that identified some draft proofing i can do. But the thing that stands out is how cold all the external walls are - around 4 degrees c, compared to 10 degrees for the floor, ceiling, double glazed windows.
I assume that means I should tackle the walls first as they are drawing the most heat?
If so next question is how to insulate... Can't do external as need to keep character of the building. And internally due to period fixtures and fittings putting 60-100mm of insulation will entail ripping out features... Which leads me to TIWI (Thin Internal Wall Insulation) which is a bit of a trade off. Says gets around 70% of the impact of full thickness insulation but at a width of only 10-20mm or so, so opens up possiblity of wall insulation with minimal disruption.
Has anyone used it? Would you recommend it? Know any installers? Or are there better alternatives?
See this government report on TIWI here : https://www.google.com/url?sa=t&sou...oQFnoECBAQAQ&usg=AOvVaw0ioChBTmsyLN0LykILoleK
Report from Leeds Uni : https://www.google.com/url?sa=t&sou...oQFnoECBEQAQ&usg=AOvVaw1xto0n4GK4ZSguZhAFMa5F
