Just picked up a copy of a Cassell work handbook 17th edition printed in 1953 entitled ‘House painting and decorating’
It certainly sounds like a hazardous job.
Here’s a few of their tips for paint stripping mixtures:-
Mixture 1. Use ½ lb of corn flour and ½ lb of china clay. Soak both in water and then thoroughly mix adding more water until 1 gallon of paste is produced.
Then dissolve 3lb of 98% caustic soda in 1 gallon of hot water and allow to cool.
Mix this with the paste and a cheap paint remover will be obtained. After removing paint wipe over with dilute acid to neutralise the alkali
Mixture 2. Pearlash and soda or potash and lime made into a paste and spread on with an old brush but these mixtures are messy and without special care will burn the hands or discolour the nails. After paint has been removed rinse the surface with cold water and when dry brush over with common vinegar.
Mixture 3. More effective mixtures are made by mixing slaked lime and carbonate of soda with water and adding paste powder? or soap and chalk.
Mixture 4. One part each of methylated spirit and acetone added to 1½ parts benzene with a little beeswax produces a volatile remover
The book also states that it is advisable to use one or two homemade tools for paint stripping in addition to a stripping knife such as a pointed piece of hard wood shaped like a butchers skewer and another piece of hard wood with a chisel shaped end. These enable the operator to reach quirks and corners and to get a perfectly clear surface. I will also need pieces of pumice stone cut into shape with an old saw. These are used with water to do the sanding down
For plaster fillers they suggest Parian or Keene’s cement or Plaster of Paris mixed with alum water or with a third of its weight of dry whiting and clean water
For wood fillers they suggest 2 parts common putty mixed with 1 part of paste white lead. (that’ll do the hands a lot of good)
Once I’m ready to paint and decorate, I think I’m going to need another mortgage for the following tools:-
Washing off or scrub brush
Two knot white bristle distemper brush
Black bristle dusting brush
Sash tool (another kind of brush)
Bevelled or ground sash tool
Oval paint brush
Ground varnish brush
Hog hair flat brush
Hog hair fitches
Black bristle ready ground varnish brush
Brush with cripple attached or self bridled brush
Paint can
Paint strainer
Palette board
Badger hair softner
Hog hair stippler
Sable writers
Sable liners
Putty knife
Palette knife
Broad stripping knife
Chisel knife
Shave hook
I then need to make up my own paint using pigments and a good base. Again they suggest white lead.
I’m off to B&Q’s then
Oval paint brush
Hog hair flat brush
Hog hair fitches
Paint can
Paint strainer
Palette board
Badger hair softner
Hog hair stippler
Sable writers
Sable liners
Putty knife
Palette knife
Chisel knife
Shave hook
