Nigel Watts
- London N7
Each day my exterior paint stripping is revealing more of the "Roman Cement" stucco on my 1840 London townhouse. The original surface, where it is in good shape, is surprisingly beautiful, especially where there are traces of the earliest pigments, but the amount of abuse is shocking. Patchings up with cement render, pollyfilla, the insertion of steel fittings which when rusted have blown a large area around them to name just a few. On the side of my house there is probably little that can be rescued of the original six feet from ground level. If the house had been faced with stone I cant believe it would have treated with the same level of contempt. Is this because Victorian and modernist moralists dismissed stucco as being fake and a poor substitute for stone?
A fightback is needed. First we need to show that stucco can be beautiful and should not be hidden behind bland, uniform modern gloss or emulsion. A limewash in earth pigments to give the appearance of weathered Bath stone perhaps?
Then we need to encourage people to restore and look after their stucco appropriately. My next door neighbour on the detatched side - an intelligent senior Guardian journalist - tried sand blasting theirs several years ago. The result was so disasterous that most of the facade had to be replastered. This was done in cement with a poor level of finish. It is quite shocking that this kind of abuse should be allowed, though I have no doubt it was the result of ignorance rather than any malicious intent. Another neighbour took the entire stucco facade off and replaced it. The replacement in this case was done in lime and with great care and skill, but then painted Brilliant White. It may have been necessary to replaster given the condition of the building but I would be surprised if all the original stucco had been beyond repair. All these buildings are Grade II.
I contacted Islington Council's conservation department before starting my paint stripping and repair work to ask if I needed permission and if they had any advice. They appeared surprisingly relaxed and had no guidance to give. I got the impression that they dont think this is particularly important.
