tycarregydwr
Hello, been a few years since I've been here. We haven't made much progress on our house because we're skint. Luckily it's still nice to live in. But we're getting sick of looking at the bare walls/crumbling plaster/mess, and are considering some bodge-job work to improve it aesthetically to a point that we could live with for a few more years.
Few questions:
* Painting over old plaster. We have several areas of lime plaster over a mix of walls (some solid walls, some lath), which is mostly original plaster, with a variety of exciting patches, where the plaster is in reasonable condition - well, at least it's still stuck to the walls. We've removed eons of wallpaper and gotten down to the plaster, some of which has flaking paint and/or thin lime wash.
1) Is it possible to paint straight over these areas? Or do we need to attempt to put a finishing coat of lime plaster on first. (We're not aiming for a perfect finish, by any means, but just some kind of improvement on bare and patchy plaster).
2) And if we can paint, what do we use - I assume standard modern emulsion, etc, is out?
* Blown plaster. There are other areas where the plaster is not ok - all on lath walls. It's being held up by as you called it 'structural wallpaper' and I'm sure as soon as we try to strip it, all the plaster will just fall down. We were going to do that, and replaster from the lath, but that's not going to happen in the near future. So, I know this is terribly blasphemous, but
3) is it possible to plasterboard these areas for now, idea being that in the future we could take the boards off and plaster properly?
4) If that is possible, could we screw the boards straight over the funky plaster-covered-with-wallpaper? Or do we need to pull down all the mess and screw the boards to the lath?
Would be so grateful for any advice. I know this is not the proper way of doing things, and we do want to do it right, eventually. But I need an interim solution.
Few questions:
