I’m just getting my wood burner ready for the chilly nights ahead. My fireplace is a modern addition to the property which originally, as an old Baptist Sunday school, had virtually no fireplaces at all, just a couple in two of the small anti rooms.. The Fire place in question (the new one) is large enough to step into (with a slight ducking of the head) and is separated or sealed off from the stack above by a tight fitting metal plate which touches all four walls of the fire place. The flue from the wood burner, (about 3ft high) penetrates the metal plate in the centre through an almost exact hole discharging the smoke into the stack. The edges of the metal plate are sealed against the fire place walls with fire cement as is the flue where it penetrates the metal plate.
There is a small inspection hatch in the metal plate that allows you to look up into the stack. The construction appears to be brickwork corbelled towards the centre and then a vertical shaft about 9” or a foot square which appears to have a brown salt glazed finish.
My problem is, the interior of the stack appears to be caked with a dark brown/black tar and there is evidence of this trickling down the metal flue towards the top of the wood burner where it has broken through the fire cement seals. I generally use logs for fuel but also any other old wood to get the fire going.
My neighbour recently gave me a load of old thin chopped up planks from an old garden shed that he had recently demolished. I haven't used this wood yet as I’m sure it would have originally been treated so I’m not sure if its any good for wood burners i.e. would it just add to the tar problem? Lastly can a ‘tar caked’ chimney stack be cleaned as it’s not your standard soot that can be brushed out and vacuumed away?
