grays85
- webheath, redditch
hi.. is this a bad word, it seems to be?
I /we are having our old cheese rooms tanked out, with approval from the conservation officer and planning dept, we are not having the walls sealed with reneder or having a dpc fitted, as this will cause the moisture to move to somewhere else, we are having cavity trays fitted into the floor around the edges of the room and a sump pump, the idea is that any moisture still passes through the wall, drops in to the cavity tray, fitted all around the edges , this runs to a sump chamber and will be pumped away. the process covers all the walls with batton and impermeable sheeting and can be completely reversed to show the original building..
Is that so wrong, opinions greatly appreciated
The basement consists of two rooms, which are 2.5mtr x 3mtr each, one will be a store (boiler room / washing machine store and the other store will be a games room.. officially as there a steel bars in the window and only one stair into the rooms they can only be called store rooms!!
