Our sitting room has literally everything against it in terms of staying warm so it's several degrees cooler than any other room in the house. It's not a small room, about 5m x 5m and ceiling height is about 2m20cm. In no particular order, here are the issues I feel cause it to be a cold room.
1. It's lower than the other rooms with three steps to go down into it.
2. It's situated at the bottom of the stairs so cold air pours down the stairs (there's no loft insulation yet) and straight into the sitting room.
3. There's a fireplace with woodburner that's too powerful (about 14kw when 5kw would suffice) which, when it's lit, sucks cold air through the house, across your sitting room and into the fire and then, when it's up to temperature, it makes it too warm.
4. The outside ground level slopes from marginally above floor level in the sitting room to just below it.
5. It has two outside walls albeit thick, cob walls.
6. Each wall has a single glazed window.
7. The floor is boarded, presumably suspended, apparently over old flagstones that may or may not be there still (I'm going by a neighbour's memory).
8. Another neighbour thinks there might be a well below it.
9. Just to add a cherry on the cool cake, a psychic lady told me that the room is "active" meaning it's haunted too!
I'm trying to ascertain which of the above contribute most to the cooler temperature of the room so I know what to tackle first so any suggestions are welcome.
