From http://wiki.diyfaq.org.uk/index.php?title=Tack_Cloth
Is this correct:
"Note this is only for use with oil-based paints. Using water-based paints (acrylic etc) a wipe down with a cloth dampened in clean water should suffice, and oil from a tack cloth may prevent the paint from adhering properly. For other sorts of paint such as cellulose the oils on a tack cloth may interfere with adhesion of the paint. Surfaces can possibly be wiped with a cloth dampened with the appropriate paint thinners"
And is raw or boiled linseed best? Or can either be used?
NT
Is this correct:
NT
