Keithj
- Witnesham, Suffolk
I'm posting this for a friend of mine - he's in the process of registering for the forum...
We have an old solid wall stone house (Longere in Brittany) that is close to a river. We have extensive rot to the existing floor and we are keen to raise the finished floor levels due to water table rising in times of flood which is not uncommon here. I have taken up a poorly laid concrete floor in the living room and have a large open space to start afresh. Can someone advise what the best way to construct the suspended floor would be? I don't want to interact with the old walls so would a set of block walls laid inside to support the new joists be the best solution?
There is also a distinct lack of any holes in the wall to allow breathing. The walls are about 450mm thick made of slate/stone. Is the option just to pick out a 'tunnel' insert some kind of tube and rebuild around the tube? I can't imagine any drilling being feasible as mentioned in other posts regarding drilling walls.
Any advice and tips gratefully received.
