Stephen
- Bishop's Stortford, Herts
Get ready for a bit of a rant!
Our telly has just packed up and to replace it with only a mid range TV will cost c. £800. I know others who have spent several £x,000s on TVs. The last full service I had on my car ost over £500.
My point?
Why are people then complaining about spending £1,200 on a survey?
Many of you are quite prepared to part with similar sums of money for things that are no-where near as important. When taken back to an houry rate the survey is not a particularly costly thing.
Yes there are good and bad in the world of surveying, but in whatever profession happens to be yours cannot the same be said?
I have posted before on surveys, how to find a decent surveyor, etc and I suggest that those wanting to know more should do a search and find those posts.
There are good surveyors around who will adapt and tailor their report to your specific requirements, who will let you join them on site, who do not report every obvious silly thing, but who concentrate on the main issues.
Yes, you are correct that surveying is not rocket science and to an extent you may be able to find many of the main issues for yourself. However, could you really be able to fully understand all forms and causes of cracking, identify all possible foms of timber decay and causes of damp, etc, etc.? Not all surveyors can, of course, but the point is that a good surveyor is worth the money. What you are paying for should also be experience of having looked at a wide range of properties day in day out.
Those who often report a bad experience are those who did not do any real research into the surveyor they were using, perhaps even used the one recommended by the mortgage lender or estate agent.
I deal with quite a few negligence claims against surveyors and whilst many are justified there are quite a few that are not. Sometimes the problems complained about are such that no-one could have identified within the scope of a pre-purchase survey. There are limitations on what a surveyor can reasonably do. If you undertake your own inspection the same is of course true.
A survey is not another form of insurance. When you are unwell do you go to the doctor thinking - if I don't get better I can sue? No, of course not. Your primary purpose is to find out what is wrong (if anything). The same should be true of a survey. The primary purpose is to find out if there is anything wrong that need concern you and needs to be taken into account in the purchase price, or considered for future attention.
The other issue is whether what a surveyor tells you will make any difference. Everyone has a different level of expectation and different levels of what they will accept. I have had some clients who would only have been put off by major structural movement (rot and infetation was not a concern to them as it was stuff they could deal with), others ran a mile at the merest mention of woodworm.
If we took the same view of other proessions and trades imagine what it would be like ...
I don't need to buy a shirt I can get a pattern and sew it up mysef. I don't need a car mechanic - a quick read of Haynes will do me. I don't need that computer geek - I can read the latest Dummies book and fix my computer.
Etc, etc.
When you break it down to the simplest form nothing is too difficult to DIY.
What you have to ask yourself is - is it worth it and do I have the time and experience/skill to do the same level of job?
With surveys it comes back to finding a decent surveyor first. I return to where I started - read my other posts on this.
End of rant.
A fed up surveyor.
My point?
Etc, etc.
End of rant.
A fed up surveyor.
