I've been recommended asking on here to get some proper common sense answers, so here goes,
Me and the Mrs have set our sights on our dream home it's awesome and pretty much a 'forever property'.
The house was restored around a decade ago, the house was pretty much a shell and the work done is a very good standard.
The house shows damp readings of the following (all results in WME)
Main walls <15%
Under stairs 25%
Hallway aperture 25%
Bathroom 35% - reason traced to water coming down an open chimney that's never been used
Utility 70% - traced to a leaking washing machine drain, now sorted and an extractor also installed
It says that the reason for the damp is indicative of DPC failure or omission - I would imagine a self built estate house from 1805 would not have a DPC but original construction would allow the property to breath. There are three fireplaces each with a chimney in the property, the stone walls are 18" thick, it has a pan tile roof. The floors are fairly level with the outside ground.
The dining room has never been used nor decorated for a decade and there is a very small piece of black mould in the bottom corner of the wall, that was all I could find on inspection today.
The report also details that we should do more to prevent condensation this includes upgrading the extraction and potentially upgrading the windows - currently single glazed wooden sash type to keep to the grade two listing of the property.
I'm unsure how much can be done? Or needs to be done tbh, the previous owner to the ones now got in bother just for altering the fence and the house also has an English heritage plaque on it but I haven't looked into that yet.
The report finishes with it saying they would get a damp specialist in and get them to quote for remedial works but reading up it sounds like there's not a lot you can do anyway. My dad is a builder and says in no way shape or form get a damp proof course injected.
Just wondered what people's thoughts are, perhaps you've got a similar constructed property? As it stands I dont find it off putting, I'm aware it won't be perfect and will require upkeep but I cannot visibly see any issues except for the very small bit in the dining room.
I have no idea what's behind the wall coverings internally, the current owner mentioned tanking, the walls are artex coated to which all but two have been flattened and plastered over smooth. The two rooms with condensation / minor damp marks are the two rooms that are never used.
The report was a bank one in order to get a mortgage but I'm thinking they're no good and would like to have a proper survey by someone who knows what's what, my second question would be is there anyone in North lincs who is recommended?
Many thanks,
Main walls <15%
Under stairs 25%
Many thanks,
