Hoping somebody might have a clue as to the cause of this sudden damp problem in our cellar...
The house is early Edwardian, and has a number of cellars, which are reasonably dry apart from the usual damp walls. The floor is solid concrete, and AFAIK was part of the house originally.
However recently we have started to find a constant trickle of water entering at the base of one of the cellar walls, which then meanders across the floor in the general direction of the cellar door - where there is a drain outside, at the bottom of the outside steps up to the driveway. The purpose of that drain I think is purely to take away the rain water that may come down the outside stairs. This trickle has been getting worse over the last couple of weeks. We have been mopping it up and now getting a bucketful every day.
The cellar floor is some 5 feet below the surface of the driveway, and I am not ware of any other drains in that area. The house is some 10 metres or so away from the road outside at the front. The weather hasn't been unusually wet.
Any thoughts as to what could cause this recent ingress of water ?
I guess the only way to get to the root of the problem would be to dig down some 5 feet in the drive
